goldduster318
Overzealous Car Modifier
Hi all,
I had installed my new 470hp MRL 340 with the Quicktime bell and my A-833. Initially, I had a few problems with the centering adapter ring being too tight, but everything else seemed ok...that is, until I started trying to hook up the clutch linkage.
The design of the bellhousing does not allow the fork to droop far enough for the clutch rod to run straight. I tried messing with this a bit and I can't get it to actuate well. There was some minor misalignment for the torque shaft, but that's not a terribly difficult fix.
So, today, I pulled the transmission out thinking that maybe I could just go directly to the factory pivot bracket for the clutch fork, but the fork does not clear the hole in the bellhousing once installed.
Has anyone else installed this bellhousing? If you did, what fork/fork pivot bracket did you use?
