diymirage
HP@idle > hondaHP@redline
hey guys
car is a 71 duster, with a 408 small block on in and a preform 750 double pumper
she was idling fine up until a few days ago 8-900 in neutral, 6-700 in gear
a few things happened over the last week which all relate to fuel delivery so let me run this by you guys and see if am correct
1 I swapped valve covers left to right. the car is running a PCV valve on one side and a breather on the other. I checked to make sure the PCV is still connected right, it is, the hose is just routed different
2 I went to install a fuel pressure gauge on my car, and when I did I killed the fuel line. picked up a cheap chrome and screwed that on up too. in the process of "making it work" I eliminated the fuel filter
3 I played with the float level a bit, trying to get things right. I went out to the track two weeks ago and messed with them there, and been messing with them ever since (if someone knows where the level should sit, under the glass, middle glass, front even with the back, let me know)
4 I replaced the chrome line with a fancy AN style one and installed a new filter and my gauge, I was running 3 PSI
5 today, I installed a high pressure mechanical pump and a regulator
set the pressure to 7 PSI
throughout all this, the engine will not idle well in gear
not very well in neutral either, but I can set it to idle with the butterfly screw, but once I drop it in gear it wants to die
I have not tinkered with the normal idle adjustment screws (bleeders are they?) because
A I don't know what I'm doing
B I don't have a vacuum gauge
and C, I think during the time I ran it without the fuel filter I may have clogged up an idle circuit
what do you guys think ?
and if it is a clogged circuit, what do I clean?
(pretty new to this whole 4 barrel carb stuff)
thanks guys
thanks guys
