[SOLD] R2 race block
Mgc340
Sioux Falls, South Dakota
Yes this is an R2 race block
Small block that was made just before the R3’s
48 degree bushes lifter bores
340 mains
Siemese bore
Roller cam bearings
I have a low deck timing cover for it
Bore is 4.175 still have the cross hatches and should be able to run as is.
Deck height I measured was 9.10
Wet or dry sump
4 bolt mains
No motor mounts
$2,800 plus shipping
The guy I bought this from bought this from Kent Ritter years ago and never ran it.
Are all five main journals grooved?
Could you show more pictures?
Do you have an engine mounting plate?
Which heads and intake does this block use?
340 mains
Siemese bore
Roller cam bearings
Wet or dry sump
4 bolt mains
No motor mounts
Does the $2800 include the repair to the cylinder crack noticeable in the last pic?
