replicaracer43
Grumpy Old Man
- Joined
- Oct 10, 2008
- Messages
- 6,051
- Reaction score
- 7,867
Good used mopar R3 race block. Casting number P4532908. Casting number shows to be siamese block capable of 4.220 bore. It is currently 4.040 (340 std) bore, 340 main journal, 4 bolt main caps. 9.200 deck height, 59° lifter angle, with 6 bolt head capability. A few of the inner small bolt bosses are cracked, but dont hurt anything. Was last run with W2 heads that didnt use those extra bolts anyway. A bit of rod damage at the bottom of 2 cylinders, but its below ring travel, and does not leak. Could possibly clean, hone and reassemble as is. Asking 1500. Located in Concord NC. Shipping might be possible.
