Race pump regulator
Moparornocar51
Austria
HI guys i have a race pump regulator like this
http://www.racepumps.com/Regulators-Street.html
There is a vacuum port i installed it to the carb!
At idle i have around 6 psi now i run them fuel pump too...
When i pull the gas the fuel pressure goes down to around 3 psi, now i was confused and checked all my fuel lines, tank ect...
but then i read somewhere in the net that this is normally when u have that vacuum port and they say i should adjust more pressure at idle and when i pull the gas the gauge will drop to 6-7psi
So now my Question is, should i disconnect that line and i also didnt really understand for what it is?
Thanks for help Peter
Thx that is what i wanna hear :tonqe: because when i disconnect it the fuel pressure will be alllways constantly!
