Race Steering Column To Aid in Header Clearance
PROSTOCKTOM
West Central Indiana
This is more of an FYI to help anyone that is building a race setup or not
interested in using a stock steering column. I just bought a dragstrip only74
Duster a few months ago that needs some upgrades and improvements. Along
with the many upgrades I am making is totally removing the OEM steering
column and going with a 3/4" DOM steering shaft and a u-joint on the steering
box input spline. This will allow for more header clearance and make it easier to
remove later when I need to service various items. The main reason I wanted to
share all of this with you is to enlighten FABO members to the spline diameter and
tooth count, so this information will make it easy on the next guy. The manual
uses a 3/4"-36 but it measures .730" on the O.D. and it is not of the same
pressure angle as most 3/4"-36 joints, so you have to be careful when buying it
to make sure it's for a Mopar spline and the power steering box uses a 5/8"-36
spline u-joint. However there are within the industry there are 3 different size
5/8"-36 spline u-joints so this is where I will help you avoid getting the wrong
parts.
They come in 5/8"-36 .600" major o.d., .605" major o.d., and .620" o.d.
The Mopar uses the 5/8"-36 .620" major o.d. spline. Stiletto Rack also is the
same one.
Personally I like using American made Sweet U-joints rather than cheap Chinese
made u-joints when my life and that of others is in question.
Here is the part numbers you need:
Sweet Mfg 401-50607 Steering U-Joint 5/8"- 36 Spline x 3/4" Smooth
The cheapest place to buy it is on eBay from a speed shop in Terre Haute,
Indiana of which I have purchased several Sweet u-joints from
for various projects in the past.
http://www.ebay.com/itm/321595952487?_trksid=p2060353.m1438.l2649&ssPageName=STRK:MEBIDX:IT $53.99 with Free Shipping
Hope this information might help others along the way.
Tom
After doing some measuring I have discovered that the major diameter on my manual box input spline in .730" , so until I get a chance to visit the local the
speed shop and verify that the above Sweet part number fits correctly since it measure .750" I wouldn't buy one yet if you read this thread and thought about
ordering one. I know that Mopar splines are strange compared to other manufactures and I will find out if this will work next week.
Tom
If you ever hit anything hard nose-on, that 3/4" shaft will make an excellent spear aimed right at your chest :poke:
How about keeping the (compressible) stock column, but cutting the tube back to the firewall? Since my car had PS and I wanted manual steering, I added a Flaming River extension and U-joint anyway.
Lots of room for the Hedman B-body headers I used in my A-body :) (The ding in tube #7 was made by the previous owner of the headers, who didn't cut the column tube).
Thanks for your concern. I guess I should have elaborated a little more on the project, but felt most would just be interested enough in the spline size it's self. I am actually
using 2 pieces of 3/4" tubing and another piece that slips over them. It is all held together with aluminum shear bolts, so if in fact I do crash the frontend of
the car the column will collapse.
Tom
hey D Charles. Where did you get the mounts for the motor plate? Did you make them yourself or can you buy them. I want that set-up for my 588" 68 cuda street car...thanks
I made the frame rail mounts. A good example is found on the BBD tech pages. It is important to use a sleeve inside the frame rail (I used steel tubing with a 1/8" wall) to avoid crushing when the vertical bolt was tightened. Of course if you want to weld the L-brackets to the frame rail then you don't have to worry about bolting it down.
There are several pics of the component parts on Page 3 of my Dart photo album.
OK, After a trip to the speed shop I can now say with 100% certainty that the 3/4"-36 Sweet U-joint will fit on the manual steering box.
Originally it would not fit because I had used a wire wheel on the input splines and apparently caused a minor burr that did not allow it to
slide on. So like the above information the cheapest place to buy it is on eBay
Sweet Mfg 401-50612 Steering U-Joint 3/4"- 36 Spline x 3/4" Round Smooth
Hopefully now others will be able to use this information in modifying their cars.
Tom
Ok, I have edited and updated the above information. I have now posted the two different u-joints it takes to install a U-joint on the
manual and the power steering boxes.
Each of the U-joints listed below have been test fit, so I know they fit correctly without issues.
Manual box takes a 3/4"-36 spline to 3/4" Smooth Sweet Manufacturing part # 401-50612
Power box takes a 5/8"-36 Spline x 3/4" Smooth Sweet Manufacturing part # 401-50607
Happy modifying,
Tom
Order placed.
Thanks for the info and the links
Murrica!
Not really saving anything by changing the tube, just cut the bearing housing back and add the u joint.
The U-joint your using is a lot larger diameter than the Sweet brand one I am using.
I am also only using 3/4" diameter tubing and it is for a race car only, so I wanted to get rid of the steering column weight.
When I finish the job all I will have to do is undo a allen head on a slip collar and unscrew the allen on the u-joint
and I can pull it all out of the way. FYI: U-joint is on all the way on both splines and to where the screw is in the
middle of the valley between the splines where the roll pin previously was.
Tom
