Trying to get everything lined up before the project starts. 1965 dart w/ 390 HP 318 w/auto. Need a replacement radiator. At this point, not sure if I'll be using the belt driven fan or electric. Aftermarket trans cooler too. Thanks
I have had my OER aluminum Rad (made in USA) …. Same shape as the OEM top tank that came in our early A-Body !!!
Total cost including shipping was $364.89 Delivered !!! Bought it in May of 2017. Well it says "Made in USA " in their (Classic Industries) catalog.. But, regardless, I still like it... One small detail I liked over most of the China made units... This OER uses the Stock Mopar radiator caps !!! And I love the Barrel top tank !!!I like that top tank a lot. I also think the OER is good quality but I think if you dig deeper on that unit, you'll find that both the tanks and core are made overseas. I'm pretty sure they just put the tanks on the core here in the USA. Anyway, it is still a nice unit. Also, it is dual 1" core which is the standard for good capacity. You can only improve on that by going to dual 1 1/4" for severe duty applications. Do you remember how much you paid for it?
I have had my OER aluminum Rad (made in USA) for a couple of years now and really like it... Cools my 65 Barracuda 273 Commando here in Phoenix Arizona just fine !!!
OER is also a Barrel top Rad... Same shape as the OEM top tank that came in our early A-Body !!! I also run the Milodon #16251 (iron 1964-69) High Volume, increased Performance water pump!!! View attachment 1715428283
The AN in/out is an upgrade we aren't doing at this time. The unit looks good. US radiator does not do 1.25" core that I know of. So that's either dual 1" or another brand. Hard to tell from the pic. If you can confirm 1.25" tanks, I think you are good to go. Good luck!Also, I went with a radiator from Bob Mazzonlini. I think US Radiator is the make. Seems to be nice quality, dual 1.25" tubes. I like the formed tanks, similiar to how Cold Case makes theirs. I requested the -16AN & -20AN outlets, which they had no problem doing for me. When it comes to any fluid transfer, fuel, oil, coolant, hydraulics, I prefer to use -AN.
If Cold Case is willing to sub the -AN inlet/outlets for me, I'll order one from them for my other car...
I forgot to ask. How much $$?Also, I went with a radiator from Bob Mazzonlini. I think US Radiator is the make. Seems to be nice quality, dual 1.25" tubes. I like the formed tanks, similiar to how Cold Case makes theirs. I requested the -16AN & -20AN outlets, which they had no problem doing for me. When it comes to any fluid transfer, fuel, oil, coolant, hydraulics, I prefer to use -AN.
You make a pretty compelling argument. I'm going to discuss this with the Product Managers to see if we could add this option.If you had the -AN option, I think IMO, you'd be the perfect radiator company...
...Something to think about.
Hallelujah!!! If that becomes a reality, I'll be a buyer today!You make a pretty compelling argument. I'm going to discuss this with the Product Managers to see if we could add this option.
That shroud is a 1965 Factory option (with A/C or Heavy Duty Cooling) that came on my 'cuda... They were a Two piece steel (upper & lower) Fan Shroud... The OER radiator I got came with side brackets ...But... Not correct for my Factory 2 piece unit so I "made" brackets to adapt the shroud to the radiator without modifying the Shroud itself or even the aluminum radiator... (Just in case I ever went back to original radiator). As for the polished fan blades... I'm glad to hear I'm not the "Only" crazy bastard on here to do that !!! The blades are a lot more "shiny" now then when I took that photo... It's an ongoing project !!! LoLWhat shroud is that? I see unique brackets to hold it on..? Guess im not the only crazy bastard to polish the blades on my fan. LOL
