I have an original 2 core radiator from an automatic 340 72 Demon. I bought it from a friends totaled Demon in 1975 for my 69 Dart 340. The radiator was modified with a lower outlet to match the drivers side on the 69 Dart. Yes I know I should have converted the Dart to passenger side outlet like it is now. When you are 26 you dont always think ahead. It has never been cleaned in 48 years. Last time I ran it was in Jan 2019 with a solid lifter mtr and no shroud. Did not work the way I wanted it to so I went with a 3 row aluminum. Shroud probably would have helped but I wanted extra capacity for future mods. Part # says for manual car but it has the automatic connections. $150 plus frt. This could also be used in a 67-69 Dart/Barracuda like I did by swapping inlet cap to right side.
Thanks FABO
Thanks FABO
