Radiator Hose Help
70sublime340
Salinas, CA
Need a hose for a dual passenger side outlet radiator and a 70 small block in a 70 dart. Didn't realize factory had a driver side upper outlet, thus the hose I bought is wrong. It's a 22" radiator that is fairly thick but looks identical to stock. Problem is its aftermarket and has no numbers on it. Can anyone help me? I want to eliminate the terrible looking flex hose I'm currently using (I now remember why I used the flex). Thanks
I'm thinking it may be a big block radiator, will a big block upper hose work on a small block with some trimming? Don't wanna use to hoses and a coupler either
