Lonewolf3165
Living the Dream!
Run a vehicle with(& this is key to what I'm saying) an adequate cooling system capacity, in 50* or less weather especially on a damp day & it should return it closer to the opening temp. It may not drop to 160* but it would be lower than 180*t-stat. The other thing to consider it the thermostat doesn't open or close fully all at once. It opens at a varying amount depending on temperature & how it's calibrated. As the system cools down closer to the t-stats temp rating it will actually start to close some or may even close completely then reopen as temperature increases again. If you have ever driven a car with a t-stat that's stuck open the temp is considerably lower than normal operating temp. Even after warm up.I don't think the thermostat opens and closes as you drive. That would be like the furnace control in your home. Instead it is a "proportional controller", which reaches a steady-state operating condition, i.e. partially open and not cycling. I think 1968FormulaS340 is correct. If you are over-heating with a 180 F thermostat, your thermostat is already fully open, i.e. beyond the proportional control range or "control response pegged out". A 160 F thermostat would also be full open there, so where is the benefit? The downside would be that a 160 F thermostat could make your engine run too cool in the winter, with poorer mileage, more emissions, and more cylinder wear. Poorer temperature control is why air-cooled engines like old VW's need a rebuild more often than liquid-cooled.
If you read my earlier post I said it probably wouldn't help matters in this case. If the t-stat isn't the problem it won't make a difference at all by replacing it. But in other cases you can regulate the operating temperature of the engine with a lower rated t-stat. I agree that problems of overheating- assuming a 180* t-stat is operating correctly- will not be cured by installing a lower temp t-stat. I was referring to another member's post here that implied running a cooler thermostat won't do anything to reduce temperatures(in a working system) & that's simply not true.
