Radio Problems
1969_Valiant
Philly, PA
A couple of months ago, you guys helped me figure out the correct wiring for an aftermarket Kenwood radio that I installed. I connected the proper wires and grounded the unit to a bolt on the steering column. I connected the harness and left the unit on my floor(I'm leaving the original in the dash). Everything worked beautifully for the first 3-5 times I drove the car. When I came back to try it again a week or so later, I connected the unit and it did not work. I checked the fuse in the radio--it is fine. With the key forward, I used a test light and confirmed that all hot wires are still hot coming from the dash. The harness has a solid connection, clicking firmly into place, and the wiring inside of it looks perfectly fine on both ends. The unit has a detachable face, but that seems to connect properly as well.
The radio has not been used heavily, and to my knowledge, it is a decent model. Is the column not a good ground? Is it possible that the radio got some type of shock from moving around a little on the carpeted floor? What are your thoughts? I don't have another radio to test, and I'd hate to replace the radio and find out that it is something else. Any replies are appreciated. Thanks a lot.
1969 Valiant I am not sure if you have the same screw but under the ash tray in the dash there is a screw. I removed that scuffed the area and used a ring connector for a good ground there. I have had zero problems since. BTW after I installed everything I put a light coat of paint down just to prevent rusting.
I would move the ground. I used the bolt the jhdeval mentioned for some lighting on my gauges, and it is a great spot, and easy to get to.
By "grounded the unit" I assume you are referring to the wire marked negative in the wiring harness. That does ground the speakers and other electronics but it isn't a chassis ground. To float a head unit you would need to attach a wire on a screw of the units metal chassis and route it to the cars chassis also.
Maybe it isn't to late and maybe static electricity has killed the unit. Good luck
