Rally Dash Bezel Drilling Process
Plymouth Pete
Windy City 3300 W Grand
I purchased a new PG rally bezel through Classic Industries around Christmas. Opened the package and thought it looked very nice. I just finished rebuilding all the gauges and tach and updating to an external voltage limiter. I now was starting to assemble all the parts when I realized that there is no cigarette lighter hole in the bezel. I called Classic to find out the deal. They checked existing current stock and they confirmed no hole. I did a little research and found the best way to make a hole would be with a step bit. The back side of the bezel does have a raised boss for the hole like my original. I then carefully measured my original and copied center onto the new piece. I clamped the bezel with stacks of foam supplied as packing to a table. I first drilled very small pilot hole until it was large enough for the first bit step. I slowly drilled and after each step I checked the measurement with my micrometer. The step bit can be steered somewhat with pressure to keep yourself aligned. The final step is 7/8ths which is just enough room for the lighter. Not as scary as I thought it would be drilling into expensive plastic.
I purchased a new PG rally bezel through Classic Industries around Christmas. Opened the package and thought it looked very nice. I just finished rebuilding all the gauges and tach and updating to an external voltage limiter. I now was starting to assemble all the parts when I realized that there is no cigarette lighter hole in the bezel. I called Classic to find out the deal. They checked existing current stock and they confirmed no hole. I did a little research and found the best way to make a hole would be with a step bit. The back side of the bezel does have a raised boss for the hole like my original. I then carefully measured my original and copied center onto the new piece. I clamped the bezel with stacks of foam supplied as packing to a table. I first drilled very small pilot hole until it was large enough for the first bit step. I slowly drilled and after each step I checked the measurement with my micrometer. The step bit can be steered somewhat with pressure to keep yourself aligned. The final step is 7/8ths which is just enough room for the lighter. Not as scary as I thought it would be drilling into expensive plastic.View attachment 1715075311 View attachment 1715075312
Nice Job! I know I had to drill the trip odometer knob hole, and it is just a small hole, but it is unnerving on such an expensive piece of plastic!
Its not there because most owners do not want that lighter well. The odd ball 68 dash ash tray was the only reason a lighter was placed up there in the plastic bezel ( where a hot lighter would melt circles around the hole ). All but 68 model have a lighter in the dash ash tray where it belongs. A large percentage have another lighter location in their console ash tray. Once in a while the aftermarket gets it right.
Thank you for what now sounds logical. I have only owned 68 models.
