Metal Map Light Bezel test fitter needed
Pot metal - they switched to plastic in 1972. This per Joel Cooper when he restored his 1971 and 1972 340 Canadian Darts.
Idk! My car is wired for rear defrost but the blower and switch is missing. I suspect one my switches was installed to cover the hole. My flashers work. Map light not so much
That one I can solve. At least for my 1970 Darts a lot of the wiring for accessories is included in the various main harnesses. This means that for many Mopars there is just one dash harness or one under hood harness or rear harness and a bunch of the wires/connectors go unused. This is true for wires leading to the AC sub-harness, to fender top turn signal lights, rear air, map and other "extra" lights, trunk light, etc, etc. for my Darts. It isn't always that way - I help a friend install new front harnesses in his 70 Superbee and he had a choice of harnesses with or without fender top turn signal lights - go figure.
Dana, I can test fit it when you are ready. Looks like my '72 map light.
