Stock 15'' rallyes came in big bolt pattern only. (5 by 4 1/2'' bolt circle, 1/2'' wheel studs) If your Demon is stock, it will have small bolt pattern. (5 by 4'' bolt circle 7/16'' studs) You can get 14'' sbp rallyes modified in to 15''. Or some wheel companies like Stocton might have new ones to buy.
The sbp wheels also have a smaller register than bbp, that's the big hole in the center of the wheel that fits over the axle hub snugly, it's very important.
I hope this helps.
