Rallye wheel question
jos51700
Green Bearing thread connoisseur
Bel-Ray
I have a set of 15x6.5 BBP Rallye wheels that I scored from a Ramcharger in a salvage yard several years ago.
Obviously, NOT the original application. What WAS the original application for these? I thought all 15" Rallye wheels were 7" wide till I found these.
Will they fit my '72 Dart ok?
It is hard to tell what you have if we can't see them. Think about it.
:worthles:
Again what is your Darts bolt pattern? If it is original then no they won't even go over the studs.
:worthles:
Well, I didn't include pics because I just figured that rallye wheels were rallye wheels. But, to be fair, some folks don't know...so I should clarify what I always thought rallye wheels were:
This isn't them, but they're just like these. I was stoked to get new trim rings from Mopar.
And yeah, I didn't think about saying it because I just got used to thinking it. My Dart is BBP on all four corners.
Look on the rim lip by the valve stem and there will be a part number that you can reference as to what they came on. As far as them fitting on your Dart, I run 15x6.5 with 245/60x15 tires on the rear of my 69 with no problems.
