[FOR SALE] Rare 1973 340 ONLY Cylinder Heads
whitepunkonnitro
Murfreesboro Tn
Rating - 98.2%
162   3   0
Bet you didn't know such a thing even existed. Casting #3671587, listed for 1973 340. These heads have unusual markings. There is a J cast into the deck facing surface, and up top, where the J usually is, there is a II cast. If you're going for an accurate restoration, these things are a must have.
They're complete with 1.88 intakes, and factory HP springs with dampers. Freshen them up, and you're good to go.
Pics to come. Asking $300 plus the ride. PM me if interested. Thanks FABO!
My 73 340 Rallye Charger had those on it.
They are also unique in that they do not have the smog tube holes drilled. I've got a pair on my 340 because my 2.02 heads have sunk valves...
correct on the II where J X O U and so on usually are cast and a J is stamped on underside of the head. I have 2 sets, also off of a 73 340s 1:88 1:60 valves
I have a set also that came on my 73 340 I switched to magnum heads and didn't realize that they were special
So, can one expect to get a better flow out of the 1:88's rather than the 2:02's? or is it just a correct thing. I'll have to see what I have. Thanks for the info.....
My buddy has a set on his 360 plymouth arrow.
They came off a 73 340 I had.
Several "commentary" posts deleted.
Please tell me - what part of this doesn't make sense to some of you?
Do I need to just start giving out bans to people who cant seem to follow the rules?
If you have a question about a part - great! Ask it. Otherwise, STFU!
Excellent!
Thanks, Joey, for superb, impartial moderating! FABO Rocks!
(This is not commentary, it's complimentary)
I will be enforcing this. Commentary such as this also fits a 318 or this wont work on a poly might be tolerated but if you dont have something good to say or pertinent, as Joey said,stfu.
Well i had a 75 Dart Sport 360, and it had 587 casting heads , i did not buy it new but from original owner .And this guy would have never changed them .Have a look at the chart above.
The II which takes the place of the usual X J, etc, is 73 only and visible when the head is in place, which makes it important for an accurate restoration.
