[WANTED] RB to B dist. adapter
I would love to tell you first to reply wins. But if the OP from the other post does not respond by the morning you get the same!
Ball is in his court. He responded quickly so we shall see. Shipping should be cheap maybe a 1/4 pound of aluminum.
P3690275 no longer made. We all need one or two. :poke:
Mancini carries two different kits, one for Mopers and one for MSD distributors. But they are $65.00 HTH, Lefty71
So my deal is sweet. Hopefully Moparmarkk will respond on the other post or otherwise!
I won’t use it and will pay it Forward, that’s what real Mopar guys do for smalls items like this IMO!
..somebody with a lathe could make a run of them things!
I'd be glad to supply exact dimensions if anyone should decide to give it a go. HTH, Lefty71
It was a tad wider than the base with a recessed step for the distributor, and stepped down OD to fit into the block. The hole was just a hole. The entire standoff height was 1/2 inch greater than the original. I did all the measurements by dead reckoning, just kept trimming it until it just fit. OEM 440 shaft is 4.00, B shaft is 3.500 from tip to flange.
