RB Torker intake
Mopar-Man
Big Block Better Burnout
Orlando, Florida
My buddy swears if I swap out my ancient Torker intake on my 440 that I will pick up a ton. Has anyone experienced this and what intake did you use? I am running 12.8:1 compression and a big 280 @.050 .620 lift solid cam. Shift points are 6500rpm.
Torker isnt abad part, but for what you have I'd run an M1 with an open spacer if it was being built now, or possibly the Indy -2D dual plane depending on the engine's use and the whole package.
