Re-Drilling Hubs
Topless69
The Twilight Zone
Does anyone know a shop in the San Antonio area that can take 5x4 front hubs & drums and convert them to BBP?
TIA
No.
I also wouldn’t want to do that.
Where is the twilight zone? And what car are you working on? Maybe some one close to you has the proper parts required to do this safely and may make them available to you for a reasonable price?
I’m in San Antonio TX working on a 2nd gen Barracuda. Looking through FABO plenty of guys have done it with no issues so I expect it won’t be a problem.
It will be alright if its done right. I recommend leaving the old studs in and cutting off the threaded part to give the old holes integrity. Space the new holes evenly between the old holes. If this is a car with 9 inch drums, I would upgrade the spindles and everything to 10 inch drums and if you go that route may as well put disc brakes on it.
I just sold a set of 9" brake hubs, conveeted to 4.5" bolt pattern. Unfortunately I deleted the picture I took for the ad, so I can't post it. There's plenty of metal on the front hubs to convert. I had them CNC machined to the 4.5" bolt pattern in between the existing holes, with a larger flat machined on the backside for the heads of the studs. I pressed in Raybestos 6184B 1/2" studs, which the shop had for measuring before machining. The 10" hubs are similar and can be machined just the same.
