[WANTED] Rear Aluminum Carpet Hold Down
goldmine
Homer Glen IL
Looking for the rear aluminum carpet hold down for a '68 Barracuda. Need both sides. I noticed that another member "Jim" was looking for this as well for his Dart. I'm assuming this could be a standard part for a lot of different A-bodies. The picture in his ad looks just like my rear area. Should be around 18'' long. I also need 1 plastic inside door vent. Any color. Thanks!
Pics
you have a fastback?
i currently do not have decent fastback extensions
these are for a notchback
if you trim them around 2 inches
they are identical to fastback ones
Yes it's a fastback. I'm assuming you trim the backside and redrill the rear hole? Do the other 2 holes line up with the existing holes in the body? The hole spacing would change trimming 2'' off of it. Looks like 1 of them is dented?? Do you have the rubber flap in the front of the door? Need 1 of them. Cost for all 3 parts shipped to 60491 or all 4 if you have the flap??
A fastback only has 2 holes
And they line up with the front 2 holes in a notchback extension
So if you trim the rear it is identical to a fastback extension
I think what looks like a dent is crud
I have the flap
Info tomorrow on price and shipping
