Rear axle leak ...
medion
Hello everybody.
I have a right side rear axle leak and I think I need to change the oil seals. Problem is I'm not sure what size is this rear axle. The car was originally a slant 6-225. Can you enlighten me on the subject ? I think the different sizes are 7 1/4, 7 3/4, 8 1/4 and 8 3/4 …
Thank you so much for you help.
Most likely it is a 7 1/4. Do a search here someone posted a chart on the different rear axles and how to id them. Dose it have a cover in the back?
This is a start...... and you could post a photo if that doesn't help!
Thank you guys for your help ! It's definitely a 7 1/4. I'll try to figure out how old it is … Thanks again !
