[WANTED] Rear Barracuda Window Chrome
67 chrome or 68/69 weatherstrip and stainless trim?
You do know that the factory 67 takes the plastic insert snapped into the gasket and the 68-69 have the stainless trim that mounts to the clips. A seller on ebay sells the 67 stuff but needs to be glued in as it doesn't fit very good.
yes have seen the 67 and 68-69 clips on Ebay, but right now have no chrome what so ever. Depending upon what I find, I'll make sure to get the correct clips. Thanks!
If you have the 67 weatherstrip it is wider than 68-69.To use stainless(68-69) you need the 68-69 weatherstrip
