[Found!] Rear bumper guards for 68'dart
panhead
North Topeka, Kansas
Good day folks,
I'm looking for a pair of good rear bumper guards for a 68' Dart. Used on 67,68,69 dart only.
See picture for reference of what I'm looking for.
Part # rear: 2768 662 (requires 2 each)
PM me here with what you have.
Thank you for your time.
I have a pair BUT they are in pretty bad shape. If you want I'll dig through several totes to find them. IIRC the rubber is bad on one and OK on the other and the chrome is so so. The car sat out in a field since 76
I think I have a set as well that might be in decent shape. I know I took some off my car years ago and I'm pretty sure I know where they are. I can try to grab some pictures tonight.
Just to confirm, it looks like the front bumper may have also had them. Are they the same front and back or is there any easy way to tell which is which?
They do look a like,
The front has a left and right part number. I believe the difference is that the mounting surface has a taper so it only fit one way.
Whereas the rear can be used left or right. (hopefully they have a part number)
I personally haven't seen a set off the car to know the difference.
Hope that helps. If you have the front as well I would be interested
Thank you
I guess the rubber on mine isn’t quite as good as I remember. The chrome is in decent shape though. Looks like there’s a little yellow paint on the one. I tried to hit them with some quick polish just to get the dust off. Pretty sure these are the rear ones. Couldn’t find any fronts, but I’ll keep my eye out in case I just put them somewhere else.
