Mopower71
Speed Demon
whats the best way to choose the best rear end gear for your car for running 1/4 mile?
It has the pro parts headers on it, same as the old McCandless headers.What headers do you run? I would spend $150 and have that converter cut open and checked out while you have the trans out.
It shouldn't be too hard to remove the passenger header completely since the headers are in pieces.
ProSport is there a calculator to figure out best gearing for the 1/8 mile. All I have seen are for 1/4 . I only race 1/8 mile.
I'm not sure, if you type in the tire size, the gear ratio, and your 1/8 MPH you might be able to play around with it. I typed in my 1/8 mile MPH from my old 9 second Dart and it seemed pretty accurate.
