Rear leaf spring shackle bushings
Aaron.M
Alberta, Canada
I got around to assembling the new rear of my Valiant but noticed the shackle bushings that my Hotchkiss springs came with are a larger diameter than stock and wont fit through the rear spring mount. The old mounts are toast anyways but where would I find new larger rear mounts that I can be certain will fit the larger Hotchkiss bushings before ordering online and finding out it's the same factory size.
I just put mine in yesterday. It was tough but I did get them in. Run a wire brush through them to get out the old rubber and lube them up. If you taper the edge a bit you can get them started easier. I then used the vice to press them in.
We took the stock A body mounts off, the tubes were only tach welded so we ground those off and installed larger tubes to accept the B body polly bushings i ordered. New leaf springs came with B body bushings.
I think the bushing sizes changed around 69 or 70 on the a bodies. The older ones were bigger, I believe.
