Rear lower quarter patch supplier 64 Valiant
30" long by 14" tall
KK-635RPL....1963-65 Valiant/Barracuda Left Rear patch panel...$195
KK-635RPR....1963-65 Valiant/Barracuda Right Rear patch panel...$195
In stock and ready to ship.....
We do have trunk extensions that can be modified to work on the 64 Valiants...
These panels can be used on the 1963-66 A-Body cars with modifications and extension of additional sheet metal of aprox. 1 inch. Done before welding to trunk floors - this easy modification can solve the problem of not having an exact reproduction for the 1963-66 A-body's. Measures 31" long X 7-1/2" wide X 7" tall
AS-19561L 1963-66 A-Body Left Hand $ 119.00
AS-19561R 1963-66 A-Body Right Hand $ 119.00
AS-19561P 1963-66 A-Body LH / RH pair $229.00 pair
Nice. Do you have the truck extensions as well?
Before you pull the trigger on trunk floor extensions please read through my threads. I just went through that same thing with my 66 Dart. The used extensions are apparently from a Valiant because they were shorter and a different shape on both ends than my Dart ones. I had read that 67-69 extensions could be modified. Well that's a stretch! They were too long, different shape on both ends, too long on the top and too short on the drop. They were a waste of money for me. The thread is the body work that was done. The photos are the used extensions I first boughtand didn't use. Check them out and send me a message if they are something you may be interested in. If I was to do it over, I wouldn't have replaced the whole trunk floor extension but just the 6" of the bottom that was rusted out. The seam can't be seen from inside the trunk and only from under the car on the outside.
A little rust repair
Photos with basic measurements. They have a few pin holes but have been blasted and epoxy primed. The photos with the measurements will take a few min. They are on my phone and upload pretty slowly.
