racyroy1
Hey guys:
I'm helping a friend with his 383 rear main seal leak, we've done this twice with two different types of seals/silicone used on the rear seal retainer cap and both times it's leaked. For what i've read this is a big problem with this engine, the second time the leak was far less than the first time and as you might all guess it's getting frustrating.
So my question is, is there a "special seal or way to install this seal and retaining cap with out it leaking". I've done it both times in the car by lowering the crank by loosening the caps and sliding in a new one etc etc. I don't think in fact i'm pretty sure it isn't the actual seal but the side area between the retaining cap and block.
Give me all of your wisdom so that I may make this headache go away.
thanks
kevin
thanks
kevin
