bricud
Cuda's Cuda
As you can the lower part of my rear quarters are shot. Someone else patched an extension on both sides which I removed to see what I have to work with. The rear valence is shot also. Surprisingly the trunk is in good shape but I was wondering what parts are recommended to replace based on what you see. Should I be replacing the entire rear quarters and valence, or is there a way to weld on the lower quarters. My guess is I'm going to be replacing the quarters, valence, and inner fenders. Not sure what they are called. This is my first time replacing body panels so I'm looking for all the advice I can get.
I am about to drop the rear end and start taking the rest of the body components as the rear frame rails are bad as well. I have been looking over many posts on bracing but not sure the best way to support the car when I replace the frame rails. Also, I was going to weld cross bracing to the inside of the body just behind the doors to keep it from twisting. Any other advice is appreciated.
Thanks,
Brian
Thanks,
Brian
