fastback68cuda
68 fastback barracuda
Driver's side rear window
So the window doesn't roll up all the way unless I pull it with my other hand. Even then it doesn't go up all the way, but it does hold while up.
Obviously I can't expect you guys to diagnose the problem sight unseen but Iw as wondering if (given how tight is is just to see in there) if there was anyplace that came to mind as a starting point for troubleshooting? Is there anything that might "typically" be a problem here?
thanks,
robert
thanks,
robert
