Rear seatbelt bolt location
SevenOFF
France
Hey guys, I’m currently working on my ’68 Cuda and trying to install my Schroth ASM Rallye 3 harnesses.
I saw that to avoid using a harness bar, I can use the rear seat belt mounting points. So I removed the rear seat, but now I’m seeing several holes and I’m not sure exactly which ones are the original mounting points for the rear seat belts, or where I should attach the harnesses. I’ve included a few photos, if someone can clear this up for me, that would be awesome!
Thanks in advance.
Here's a terrible pic of mine.
There should be plates with nuts welded behind the holes.
If no holes, typically there are dimples in the floor.
The bolts in your pics with the big integral washers hold you exhaust brackets. Even if you reconfigured with a longer bolt they are not sufficient for a seat belt.
