mopar56
Has anyone ever put rear shoulder belts in a Duster? My grandkids will be rolling around in my son's 70 Duster thus summer and would like something safer than lap belts.
If you do you'll have to construct an anchor point in the inner structure of the car. The extra point of contact doesn't do you any good unless it's as strong as the other two. Fortunately the C-pillar has some decent structure to it to begin with, but you'll need an anchor plate behind something solid in order to even attempt it. Otherwise it will be LESS safe.
Yes, they were installed in B Bodies, but never in A'sThey were available as factory equipment.... mine are factory from a 69 Charger R/T SE
They are pretty heavy, but would fit in aa medium Flat Rate box, so shipping would be something like $45.Thanks for all the answers I am surprised to here they were even a thought back then so no this Duster dint have the fold down seat his 74 he had did what is involved in putting them in and Tony the ones you have what do they weigh? Cause I am a long way from you in Canada
Yes, these have an anchor point at the C Pillar, and that anchor point could actually be bolted to the rear inner wheel house, and then fed through the package tray.your 74 might have threaded bolt anchors on C-Pillar. If not you will see 2 slots about 3"s long and 3/4" wide on the outer edges of the package tray about 3" from the front edge if you look from the underside in the trunk.
I dont see why a guy couldnt duplicate these with a long section of seatbelt. Just sew a loop in the end and make a dogbone out of 1/2" steel shank about 3" long.
Hey Tony what exactly dose this set up include you have? Is it just what us needed for the folding seat or the seat belts to? Also could I use the original seat?
