Mattax, which shocks would you then recommend?
If they are not broke, don't fix.
I diss'd the KYB's because like many products they are promoted as a bolt-on upgrade for better handling. Truth is they have more damping, but its not well calibrated for most.
I don't know Monroe or Gabriel product lines. They basically sell serviceable replacement shocks. It's been years since I've needed to buy a basic shock. I can't imagine you would go too wrong with any of their shocks, nor do I believe they would perform noticbly better than what is on the car unless something is worn or leaking. If you can't tell while driving, a
quick crude check is to bounce each corner of the car to if the movement is damped out or it keeps bouncing.
For the person really into spirited/sporty driving, then it may be worth looking at shocks that probably can deliver - especially when matched with some other components. In the bolt-on catagory that would include Bilsteins sold by Firmfeel and maybe the Fox from Hotchkiss.
If you really want rake, but just for the look, not sure I can help. But I will say, especially in your position, its probably better doing it by dropping the front hieght a little by cranking the off the torsion bar adjusters. Also, the front can be raised back relatively easily. No parts needed. Slight alighnment adjusted worth doing. That's it. Remember, all modifications have consequences. If you like hot rodding, that's cool, but don't be too surprised if something breaks or doesn't work out as intended. It takes a while to learn enough to filter the majority of the chaf from the wheat. If you do use a high arch spring set, then check pinion angle, shackle angle and shock length. Also stay aware of the effect of raising the rear roll center on your kentucky downhills.
