Rear Sway Bar/Spring relocation
hardyrw1
Bothell
Is any one running a rear sway bar after moving the springs inboard for a mini tub? If so what type of set up are you using?
I relocated my springs, but didn't do a mini-tub. Maybe these pictures will help you anyway.
At the time, I didn't know that a Helwig 6909 would work, so I had Helwig bend a special 1" diameter bar. Vertically it is flat except for about a 1-1/2" upward bend in the center where it passes over the differential case.
