Rear Tail light Harness Plug... Stock Location? (65 Barracuda)
MonkeyMadness
Yorba Linda California
Hello,
In need of the stock location for the 5pin Rear tail light harness plug?
I just received the rear a harness I got from yearone and want to install it before I move on to carpet and insulation. When I test fit the harness as I believe it "should" be installed. It puts connecting harness plug at the corner of the drivers door. I have not installed the dash or the dash harness, and I'm a bit worried about finishing the rear harness just to find out Its not installed correctly.
The rear harness was removed before I got the car so I can't look back on my teardown pics sadly so I need your help.
thanks
j
The rear harness i removed from a 65 Barracuda I parted out had the connector farther forward and tucked in that large hole in your pic and was still connected to the dash harness connector hidden by the kick panel.
Ditto I recall for my 64 & 65 A's (long ago). I recently was in there on my 65 Chrysler and looks the same, with connector tucked into that big recess. So, need to pull the harness forward more.
