Rear window crank handles... where to buy?
71 Duster 440
Quarter Life Crisis
Long Island, NY
Do any of you know where I can buy the rear window crank handles for my 1967 Barracuda fastback? I only see the front crank handles listed, are the front and rear the same? I have the original fronts, but the two rear cranks are missing. I'd like to roll all of the windows down in this thing... at some point! :D
Thanks in advance for the help!
Chris
The front and rear are the same. If you would like a shorter handle for the rear, the little vent window winders from a 67 Fury match.
I got some rears from the Help Section at an auto parts store, make sure to read the package and get the "Mopar" ones. I had to get some and then cut them off and reinstall the knob in order to clear a roll bar. The wing window handles would be nice if you can find where to get some.
here's what mine look like. The vent window winder has a tapered counter bore where the correct window winder has a square bottom counter bore. easy to alter though.
