The drivers side bottom molding on the rear window has a hole where a screw should go. There is a screw on the passenger side. Is there even supposed to be a screw here? If so I tried using one but there's no hole in the actual body. Would I need to drill a small hole first?
1971 Dodge Dart
1971 Dodge Dart
