JasonR
Member
Car: '69 Dart Slant Six w/ factory air conditioning.
I'm working to get the AC up and running in my Dart, and just finished replacing some of the missing wiring. I have a question about the idler/tension pulley...
It is a single-v pulley with a cup washer and a seal for the pressed-in shaft bearing. Any idea if this is rebuild-able? I couldn't find anything in the service manual, and I can't seem to locate a replacement part for the whole assembly.
It is a bit stiff, but I'm about to go get a belt to put on it and in case it is shot I'd like to know where to turn. The heat is on here in AZ!
Cheers,
Jason
Cheers,
Jason
