[SOLD] Rebuilt & Upgraded Door Hinges
Vancouver BC
Here's a pair of door hinges rebuilt and heavily beefed up by John Rivinius. Zero miles (swings?) on them; had 'em done and never got around to installing before the car went away. The lower hinges each have a new hard steel pin and a hard steel sleeve sturdily welded in so the load bearing area is the whole width of the hinge rather than just a small area at the top and bottom. The sleeve has a zerk fitting so these hinges can be greased—these hinges will practically never sag out. New springs in 'em, too. The upper hinges are line-bored, bushed, and have a new hard steel pin. All four hinges are in primer; paint as you wish.
They fit all '63-'76 A-bodies (front doors on a 4-door or wagon). They also fit '66-'70 B-bodies (front doors on a 4-door or wagon), and '72-'93 D- and W-series pickup trucks and Ramchargers (yes, really).
$169/set plus postage from Seattle, Washington, USA—send me a PM.
