Reconditioning Factory AC Outlets
charliec
richmond texas
Have any of you ever done one of these before? I thought I would take everything down to the barest component and recondition them since the old ones were so nasty. The one on the bottom is as assembled, i.e. I never took it apart. The other one is a pile of pieces that it will take way more dexterity than I have to put it back together...SO many pins, holes, keepers, swivels, etc., etc., etc. I can see from the whole one how it is supposed to fit together, but I can't make all the holes line up with all of the pins on three separate rows all at the same time.:BangHead::BangHead::BangHead: At this point, I'm just thankful that I still have at least one still assembled so I have an idea at least as to how its supposed to go together.
If anyone has any bright ideas, I'm all ears.
louvers are equally spaced. Measure and cut a comb like fixture in wood. Not that I've done this exact chore before.
Yeah I have the same setup and it does look tedious. I believe @Jim Kueneman has taken them apart before.
Would a magnet help?
A magnet might help where there is iron but those louvers are pot metal. Many I have seen were pitted badly. The pins that mount them are small as sewing needles and will snap right off.
I discovered long ago that the black plastic louver sections from the later model will interchange.
Best plan in my opinion is buy a later model part and have a go at the DIY chroming paint. I watched a video recently of a guy doing side by side comparisons of 6 to 10 (I forget) different products. Top 3 finishes were so good that only factors remaining were cost and/or availability.
Oh they are bear. I had some 3M vinyl tape 1/8” wide that helps. If you want you can ship it to me and I’ll put to back together
Oh that is a '67 one they are easy.... the '66 ones don't have that center section with the screw for the top plate they have another vane! :rofl:
I watched that video also. In fact, I just ordered the paint that he used and recommended. I've been wanting an airbrush setup anyway. I might look into the later model louvers if I can't figure out how to put this thing together. Jim also has a good idea....ship it to him!!! :lol: I guess he just doesn't have enough frustration in his life.
I got pretty good at putting them back together. I actually have a 67 vent that I was using for parts on my 66.
I have a complete one that is near mint condition if interested. I didn't see any pits at all. I could get better pictures. Out of a 68
Almost done.
Hey @charliec depending on the position in the distribution duct the thumb tab goes either on the top or bottom. Which way was this one.
There you go. I’ll try to get it out from here this week. Else it will go out when we get home next week.
