Redoing my 63 Dart
oldguy
Reno, Nevada
I'm going to attempt to show what I've had to rebuild on my Dart. Started by trying to fix some cracks in previous body work. really found a mess under the Bondo! Since I have to do the work thought I might try to share my pain!
I am first showing what I found and then what I am doing to repair it. Will post more pics as I go. Plan on satin black when I get it done. Mike
Just noticed I probably put this in the wrong place. If that's so would someone please move it? Thanks Mike
Got some work done so it's time for an update. This time the door repair to date. Used an old door for a patch. Used JB weld as an epoxy. Wanted to try fixing the door with out welding. I'm welding the rest of the body work just wanted to try it on the door to try to cut down on the warping. Thought it would be worth a shot. Anyway here's the pics. More later. Mike
