StreetSleeper
I come across good deals on stock bore pistons, some Keith black hypereutectic, some forged, not the old forged pistons that expanded with heat, modern forgings.
I have 2 standard bore blocks, & many are for sale standard bore at the moment. (318’s) /
There are forged pistons for sale, discounted, that are standard bore pistons.
What do you look for to consider building an engine with its existing bore?-when is it worth it, with high (street) use expectations?
As I hear it, the magnum blocks are often low on cylinder wall wear.
A ridge at the top-if it does exist, would a three stone hone remove that enough without hurting other places on the bore besides the common top ridge line?
You want to catch it with a finger nail if you question the ridge correct?
(Can I measure top, middle, & bottom bore thickness accurately myself?)
Cylinder straightness -can I measure that?
I understand that one wants diagonal cross hatching to catch & retain oil.
I have heard conflicting information regarding how fast to insert & retracting the honing setup as you hone-any advice there would be appreciated. Thank you
Besides cleaning, magnifluxing, decking the block & Aline honing the crank journals, what other services would you concern yourself with
Regarding a 300 + hp street build.
This concept applies to other enthusiasts that might come across a used .020”, .030”, .040”, .060” set of pistons and block as well.
Or do you think trying to cut corners with the bore & cheap pistons is a waste of time?
The ‘good’ pistons for a 318 run a premium, I am on a budget, and am trading time for money if I try to do everything perfectly.
Thanks for your input.
