dustoff440
I still have to put it back together;. It's a 850 cfm 9077 off of a 400 lean burn a/t. I should have taken before pictures. The only thing left to do is drill a hole for vacuum for the distributor advance. Lean burn carbs didn't have ported vacuum for the dizzy, the distributor advance was fixed. I also have to find a set of 1966 metering rods(any of you guys who have a spare set), I found a source for new jets.
