crycho
How do you remove a 4sp shifter that in a slip in?
thanks!!You use a .010" feeler gauge and push it down on the driver's side between the shifter handle and spring clip. You only need one feeler gauge. There in no locking tab on the passenger side.
Im going to post pic of the shifter I think it bent incorrectly because I'm hitting the dash in first gear.thank you gentlemen it worked!!
That's not good for me. Need an A-body! Anyone?That a pre 1971 B-body console handle.....
