Removing a Holley "slide out" choke plate
Brooks James
VET, CPT, Huey Medevac Pilot
Fruitland Park Fl
It seems that the older Holleys have screws that can be removed. This one im working on has the plate sandwiched in the shaft.. I tapped on the shaft but it movies very little
Its not moving enough to bind the linkage rod/tab..
Ideas ?
I use one of these and flatten the lower indention retainer before removing. If you need to reinstall it, it can be knocked back into shape with a chisel over a vice opened the width of the tang. It will tap back in from there.
WeldingSupply 12LC-3 $14.99
