removing an insterment cluster (66 dart)
1966 dart wagon
Sioux Falls, SD
I have a 66 dart wagon and i would like to be able to remove the insterment cluster, I took out the 2 far screws on the left and the ones in the ash tray so i could see if there was any screws along the side if i get behind the cluster and stick my head up behind the dash i can see two screw ends sticking towards the front of the car so it appears there are some screws in the right side of the cluster but the heater cluster plate is in the way so this means i have to remove the heater cluster plate to get to these screws how do i remove that :-k
i think my volt reg is bad cause my temp guage moves but gas doesnt, and when i swaped volt reg(used from a van out back) it didnt seem like it wanted to go in all the way :angry7: maybe i can push on it harder and whatnot if i have the cluster out, also i might have the speedo rebuilt
