Removing Heater/Radio Bezel '70 Dart
Robj
Redding, California
How do you remove this Bezel? I took the screws out of the top and the radio is out. I know the heater controls are attached to it but even the bottom where the radio mounts is still firmly attached to the dash. I've looked behind with a mirror but don't see any fastening points. I'm missing something back there. Thanks.
There are about 1/2 dozen speed nuts on the back holding the trim to the dash. There may also be 2 studs that secure the bezel in the heat control area. Although from a different year, the included pic shows the studs for the speed nuts and the 2 studs on the back of this bezel. I just recently removed a 70 trim plate and can attest to their existence!! Hope this helps, Geof
