My 74 Dart Sport has 72 Duster doors. How do I remove the inside emblem without damaging the paint or the emblem?
Thanks, Steve. I'll give it a go in the next day or two.They are pushed into a clip. Put masking tape around the emblem and use a heavy putty knife. Put it all the way through behind the emblem next to the peg. and go back and forth from the front peg to the rear peg and top and bottom slowly prying it out of the clip. Then the clip can be removed. If they are brittle they will break off. Slow, even and patient is the key. Pushing one side all the way out usually breaks the other side so go evenly with slight rocking pressure
Worked great. I used two layers of tape and a thin 1" putty knife.They are pushed into a clip. Put masking tape around the emblem and use a heavy putty knife. Put it all the way through behind the emblem next to the peg. and go back and forth from the front peg to the rear peg and top and bottom slowly prying it out of the clip. Then the clip can be removed. If they are brittle they will break off. Slow, even and patient is the key. Pushing one side all the way out usually breaks the other side so go evenly with slight rocking pressure
