Removing Inside Door "Duster" Emblem
SpeedThrills
Very South Jersey
My 74 Dart Sport has 72 Duster doors. How do I remove the inside emblem without damaging the paint or the emblem?
Do you mean THESE badges?
The service manual supposedly has a graphic but I suspect that they have pegs that go through the door shell with speed nuts holding them in place.
They are pushed into a clip. Put masking tape around the emblem and use a heavy putty knife. Put it all the way through behind the emblem next to the peg. and go back and forth from the front peg to the rear peg and top and bottom slowly prying it out of the clip. Then the clip can be removed. If they are brittle they will break off. Slow, even and patient is the key. Pushing one side all the way out usually breaks the other side so go evenly with slight rocking pressure
Thanks, Steve. I'll give it a go in the next day or two.
Worked great. I used two layers of tape and a thin 1" putty knife. :thankyou:
