I have taken the two bolts underneath the dash that hold the steering column in place. It is now loose and moves up and down about an inch. This is not enough clearance for me to remove my very brittle instrument cluster so I’m looking for guidance on how to lower it down further. Pictures or illustrations would be helpful because I’m a rookie. I am also having a hard time reaching anything from below to disconnect, speedometer, cable, etc. once I get the steering column down far enough, will the instrument cluster pull out far enough for me to disconnect things behind the cluster?
