removing trim
RTSduster
Active Member
How do you remove the trim strip from the side of the car without screwing up the paint? What will remove the glue residue left behind?
Heating it with a heat gun or hair dryer should help. If it wasn't put on before tha paint was cured it should come off ok.
3M sells an 'adhesive remover' that works well to remove adhesive.
Dallas
